Help with Photos
Well we have an easier way to upload and save photos to insert in the forum. Now you can do it from your members control panel.
1. First use the resizer below to resize your photos then follow the directions to upload.
Here is a easy photo resizer program to resize your photos prior to uploading them. Just click on the link below download the resizer.
http://www.c10trucks.com/photo-resiz...o Re-Sizer.zip
Goto step 2 after you have resized your photos.
2. Select User CP
3. select from the side menu Networking and then click Pictures & Albums
4. select Add Album
5. Title: name the aldum here any name you want
6. press the submit button
7. Select Click here to upload pictures!
8. Brouse to photo on your computer
9. click upload photo
10. click save changes
11. then click on the photo untill it enlarges you will then see see the links under the photo so you can copy the link and insert the photo in the forum
Quote:
Special Note, if you click on the photo gallery from the navation bar above and go to your album that way you will not see the links under the photo when enlarged, You must first click on user cp from the menu above and then click on pictures and albums and then click on the photo you want to get the code, First enlarge the photo and the code will be under it
Hope this helps
Otis
Also when anyone clicks on your member profile your photos also show up in your profile.
Hope this helps
Otis
