Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Tube Rolling
Results 1 to 7 of 7
Thread: Tube Rolling
    Administrator & Sheet Metal Junkie Prostreet's Avatar
    623
    Tube Rolling
    Well, I finally got to use my new tube roller. This is just one of the jobs I had in mind when I purchased the roller.
    I started by marking the center Of the tube so I could track it with the cardboard template. I ran a slight radius to start.
    After rolling a bit more, then checking it with my template.
    I know after a bit I'm going to have to switch to the tube bender for the hard radius.
    Here's what it looks like in place...... Being this was my first roll and bend this might end up being a test piece.
    Thanks Steve
    Pro Metal Shop
    http://prometalshop.com/
    Hot Rod Sheet Metal Fabrication and Shaping Shop.
    Tools of the trade. Looking good!
    I'd be making pie cuts with a sawzall, bending in a vice and then mig welding and grinding. Probably would take me 4 hours to do what you can do in 2 hours, and your end product is structurally superior.
    anim_25 with the new tool.
    623
    Thanks John
    I'm bending the right side today. I'm going to leave the tube longer on the bend to go further down the back tail panel. The first piece was actually a piece of scrap that I had used the keep the door jam square and had some tack welds I ground off.
    Thanks Steve
    Pro Metal Shop
    Is that a 'glass bodied 55 you are working on?
    623
    No, all steel.... but its a lift off body, so there has to be more structural work done.
    Thanks Steve
    Pro Metal Shop
    Administrator
    182
    I enjoy seeing how things are made.
    Otis
  8. #7
    623
    Well lots to be built here, Otis...
    Thanks Steve
    Pro Metal Shop
  9. Remove Advertisements
