I need to know what 70's or 80's rear end will fit my 65 chevy C10. Thanks. Lewis
Are you staying with 6 lug or changing to five, they used 6 lug til about `68 I believe, the housing are the same width up to `70 but change to five lug in 69/70, any of these will bolt right in, you can use any rear axle up thru ``05 with some minor changes to the track bar, a new kit from POL and perch blocks will need to be added on.
I think 4x4 6 lug to 72
You are correct Goose, althought the 70 on up are 1.5 inches wider they still fit, he will need a track bar conversion.
Thats right,the 4x4s were leaf spring duh,got hung up on the 6 bolt thing.lol
I want to change to five lug
Five lug started in 71 with C10 which was a 5 on 5 .
Thanks Steve
Pro Metal Shop
http://prometalshop.com/
Hot Rod Sheet Metal Fabrication and Shaping Shop.
He can also redrill the rear hubs for five lug and just buy new drums....just a cost thought.
There are axle conversion kits available for the stock housing also.
Ray
All my life, I've been told I'm a "Bad Influence"
Ray thanks for waking me up...I knew that too, CPP or ECE POL they all sell them...
