Fuel gauge not working?
Results 1 to 4 of 4
Thread: Fuel gauge not working?
  1. #1
    Junior Member Elvis56's Avatar
    Join Date
    Jan 2013
    Posts
    9
    Hello guy's,
    Just a quick question.
    Spring may finally be around the corner and my Wife & I are getting the itch to drive her 72 Cheyenne. The problem is, the gas gauge is always stuck at 1/2 a tank. Where & how should i start the problem solve? Should i get a new float first or a sending unit or both. Just wondering if anyone has encountered this problem before and what was your findings.
    Thanks in advance for your help.
    [SIGPIC][/SIGPIC]1972 Chevrolet Cheyenne Fleetside Short Box purchased in Arizona (Wife, 2nd owner)
    1956 Chevrolet Bel Air Sport Coupe (Barn Find..mine)
    1967 Chevelle SS 4 speed (mine)
    1974 MGB Convertible, frame up resto (Wife's)
    2005 Pontiac Grand Am GT 2 Door (Wife's)
    2006 Ford XLT Pick Up...sorry (mine)sign0013
    We're tied!
    When it's over and all said & done "The man with the most toy's....THE KID'S WIN!!!anim_63
  2. Remove Advertisements
    SilveradoOwners.com
    Advertisements
  3. #2
    Senior Member 406Rich's Avatar
    Join Date
    Jan 2013
    Posts
    387
    I would start with the sender, but that was my case, just lucky, not sure, sender was all corroded once pulled out and almost fell apart. Ecklers sells floats and senders separetly, but the cost is cheap enough just to buy them both and be done with it..
    `37 Ford Coupe, 406/350/324 posi
    `64 C10, 350/350/373 posi
    `68 Dodge Dart 370/904/325 sure grip
    `69 Camaro RS/SS 350/350/307
    http://photobucket.com/R51506964
  4. #3
    Junior Member 1971BB427's Avatar
    Join Date
    Nov 2012
    Posts
    10
    Before you buy a sender, test what you have to ensure the gauge is good. Pull the wire off the sending unit and turn the key on; it should go to "full". Then use a jumper to hook into the sending unit lead wire, and ground the wire to a good ground source, and it will go to "empty".
    If it performs correctly, then you can proceed to a sending unit knowing the gauge is fine. If it doesn't, then you need to look at the gauge, or wiring before a sending unit is purchased.
  5. #4
    Junior Member
    Join Date
    Jan 2018
    Location
    Santa Rosa, CA
    Posts
    4
    what would cause an 04 duramax lly to idel rough at times ? Has new fuel filter, and manual primer system
  6. Remove Advertisements
    SilveradoOwners.com
    Advertisements
Similar Threads
  1. Ask & Answer Questions about Fuel Systems, Fuel Injection, Carburation, Superchargin
    By c10 in forum Fuel Systems, Fuel Injection, Carburation, Supercharging
    Last Post: 01-14-2023, 04:12 AM
  2. Oil Pressure Gauge?
    By morleybc in forum Electrical Questions and Answers
    Last Post: 10-03-2014, 10:53 AM
  3. Truck Gauge Clusters.
    By Gordon Hampton in forum Classifieds Buy,Sell, Wanted, Trade, Free Stuff.
    Last Post: 03-27-2014, 02:03 PM
  4. Fuel tank update for LS engines
    By runem in forum Fuel Systems, Fuel Injection, Carburation, Supercharging
    Last Post: 02-18-2014, 01:34 AM
  5. Ask & Answer Questions about Fuel Systems,
    By c10 in forum Electrical Questions and Answers
    Last Post: 12-28-2012, 04:06 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
