Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Bead Roll Table
Results 1 to 6 of 6
Thread: Bead Roll Table
    Administrator & Sheet Metal Junkie Prostreet's Avatar
    623
    Smile Bead Roll Table
    Hi Guys
    For the longest time I've needed to build a table for my bead roller, so I didn't have to rely on someone holding up the panel I may be working on so it don't sag as I'm beading or shaping.
    So I mounted it to my bench, and started building my table. A table is super handy, but at times it may get in the way. So here is what I'm came up with ! !
    I made it large enough so I could lay a larger panel on it and concentrate on the die instead of watching the panel that it don't sag and deform as I'm rolling it threw any particular die set.
    How ever there are times I need to shape a panel as I'm rolling and I will cause down pressure, and the table will get in the way. So here was my quick cure ! !
    I'm still going to make a quick prop for it, as its on hinges. This makes it so I can change dies, and it will quick detach so I can remove it all together.
    This makes it nice also for small panels so you don't have to constantly grip on the metal and you can move a with a bit more freedom.
    Thanks Steve
    Pro Metal Shop
    http://prometalshop.com/
    Hot Rod Sheet Metal Fabrication and Shaping Shop.
    You do amazing work.....
    Senior Member
    Dec 2012
    308
    As always,great job Steve.I really like that "KATE" placard.Very cool
    623
    Thanks Guys
    I made a light offset in some tubs I'm building in a 55 and the table helped quite a bit but I still had to chock up further out the bench, but they were quite long at 40 inches. And I'm also thinking I may be replacing my foot feed pedal, as its getting a bit sloppy and give me a slow response, and then a quick excel, which keeps me on my toes....
    Thanks Steve
    Pro Metal Shop
    Junior Member
    Dec 2012
    6
    Do you normally have a standard pattern in mind for most parts or does the theme of the vehicle determine what pattern ends up being?
    Theme meaning, street car, race car, even how the parts are cut / laid out.
    Or just for the stiffness of the individual parts and just keeping a clean pattern.
    Terry
    I might be parinoid, but that does not mean they are not watching me.
    623
    Hi Terry
    My patterns usually come from both the type car build and the personality of the customer, and I try to incorporate that into design ! !
    Thanks Steve
    Pro Metal Shop
  8. Remove Advertisements
  1. Bead Rolls Without a Roller
    By Prostreet in forum Metal Fabrication & Repair Questions
    Last Post: 01-08-2014, 06:56 PM
  2. Some Bead Roll Work
    Last Post: 08-12-2013, 02:24 AM
