Ask & Answer question about Headers and Exhaust System - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Ask & Answer question about Headers and Exhaust System
  1. #11
    Senior Member 406Rich's Avatar
    Jan 2013
    387
    Here you go hedman shorty part # 69646
    hedman full length # is 69096
    doug thorley # 3004
    summit 69640
    This should help you get started....NOTE some hedders not compatible with manual transmissions due to clutch linkage read the fine print...
  3. #12
    Junior Member 1971BB427's Avatar
    10
    Quote Originally Posted by Blue Goose View Post
    I cant recall chevy ever using gaskets for exhust manifolds from factory.Always been metal to metal.Gaskets usually caused problems over time.Headers a different story of course.Installed sanderson block huggers on the ramjet without gaskets and was surprised no leaks
    You must be a pretty young guy! Chevy used gaskets on exhaust manifolds for many years. Wasn't until the late 70's or 80's when they stopped putting gaskets on exhaust manifolds.
    For headers, I always use the stock type exhaust manifold metallic gaskets. Never had leakage issues once I started using these style gaskets.
  4. #13
    Hooker Headers..
    Quote Originally Posted by Charles View Post
    What headers work for 64 C10 with 350 engine & trans?
    I've always had good luck with Hookers http://www.summitracing.com/search/y...hooker-headers
    bowtier If you can't stand behind our troops, perhaps you should stand in front of them bowtier!
    My 1965 C10 SWB Step Side Build Thread
    Some Technical Threads I have Posted:
    Frame Mounted Gas Tank - Rear Frame Notch - Upper Shock Relocation
    Track Bars, The Long & The Short Of It
    A smart man learns from his own mistakes, a wise man learns from the mistakes of others.
  5. Remove Advertisements
  1. Ask & Answer question about Interiors Questions and Answers
    By c10 in forum Interiors Questions and Answers
    Last Post: 05-03-2018, 01:02 PM
  2. Ask & Answer question about Paint & Bodywork Questions and Answers
    By c10 in forum Paint & Bodywork Questions and Answers
    Last Post: 09-20-2014, 06:23 AM
  3. Ask & Answer question about Transmission and DriveLine Questions
    By c10 in forum Transmission and DriveLine Questions
    Last Post: 07-10-2013, 11:47 PM
  4. Ask & Answer question about Engine Building, Hi Performance
    By c10 in forum Engine Building, Hi Performance
    Last Post: 12-28-2012, 04:06 AM
