Ac
Results 1 to 2 of 2
Thread: Ac
    Junior Member
    Jun 2018
    1
    Ac
    2005 silverado 1500hd LS. My ac is not blowing cold air. The refrigerant is ok and the compressor cycles. I noticed that the low and high side are on the same line. Low is cold and high is hot. Water is being removed from air. What can the problem be? It is getting hot in Fl and I dont have the money for a shop.
    Junior Member
    Oct 2018
    8
    Have you had the condenser checked?
  4. Remove Advertisements
